Laserunit Philips type RCD2 gezocht
02 mrt 2022 23:06 - 02 mrt 2022 23:12 #93990
door tcfkat
Beantwoord door tcfkat in topic Laserunit Philips type RCD2 gezocht
Hello dear community!
I'm new here and this is my first post. I'm sorry I do not speak Dutch although I can (hardly) read it. My mother tongue is German and French/English is no problem.
On topic: I work for a local Repair Café and since January I have a Philips AK701 CD changer here for repair. Today I discovered that it has the same problem: the brown gear wheel is gone, while the white ones are ok. Finding the complete RCD2 pickup is hopeless. The used CD changers offered for sale seems to have the same problem, so buying them for scrap is useless.
Imho the wheel is to small for printing it with a standard 3D printer. But I found on eBay an offer (#164857587820) from Poland. The seller has re-manufactured (molded?) the gear wheel. For 13 Euros including shipment the owner of the AK701 is willed to give it a try, so I ordered the wheel today. The same seller has over 300 re-manufactured parts to offer, which may help repairing hopeless cases. (No, I'am not affiliated with him!)
If I do not forget I will keep you informed if the repair succeeds. I hope the laser itself is still usable.
Hope this helps and best regards,
Eric
Eric
Laatst bewerkt 02 mrt 2022 23:12 door tcfkat.
De volgende gebruiker (s) zei dank u: Francois129, FMX
10 aug 2020 00:11 #84991
Beantwoord door Bert Kn in topic Laserunit Philips type RCD2 gezocht
Er wordt door de TS gevraagd om een Laserunit RCD2.
Niet om adviezen die de meeste van ons wel kennen.
Voor een klant, familielid kan een apparaat een speciale betekenis hebben om juist dat apparaat weer gerepareerd te krijgen.
En dan is het aan de klant, familielid wat de kosten mogen zijn.
De volgende gebruiker (s) zei dank u: Francois129, v1ncent
09 aug 2020 22:39 #84990
Beantwoord door Rene Daemen in topic Laserunit Philips type RCD2 gezocht
Francois ,
Een klant moet ook wel eens kunnen incasseren dat niet alles het eeuwige leven
Heb .
En ook niet meer gemaakt kan worden.
Ik heb ook wel eens iemand gehad met een platenwisselaar koffer van philips
Met een AG1025 . Nu dat had vast zwemles gehad.
Ik heb hem duidelijk gemaakt datnhij beter naar wat anders kon gaan uitzien
Omdat dze zwemles had gehad stijf van se corrosie.
De CDM loopwerken waren goed met swingarm die met tandwielen geven problemen.
Ik zou uitkijken naar een andere speler philips oudere generatie
Of technics had ook dit systeem sony moetje links laten liggen vaak probleem met laser overslaan als een vliegland.
Heb .
09 aug 2020 19:52 #84989
Beantwoord door Francois129 in topic Laserunit Philips type RCD2 gezocht
Ja Huub,
De klant is koning.
Meer zeg ik daar niet op.
De klant is koning.
09 aug 2020 19:27 #84988
Beantwoord door Huub in topic Laserunit Philips type RCD2 gezocht
vaak in de kringloop 10.E
dus waar ben je mee bezig .
09 aug 2020 17:41 - 09 aug 2020 17:43 #84987
Dank u, blijkbaar heeft deze CDC niet alleen het probleem van slechte tandwieltjes.
Ik ken wel iemand die professioneel (die ook de Lenco lift stukjes gemaakt heeft) een 3D printer gebruikt.
Eens informeren of hij dit kan, wat het kost en is men bereidt dit te betalen?
Voor mij wil ik wel eens “zot “ doen. Maar dit is voor iemand anders en dan denk ik: beter een nieuwe cdc kopen.
Laatst bewerkt 09 aug 2020 17:43 door Francois129.
