Restoring a Philips F8X82a
07 jul 2023 12:19 - 07 jul 2023 12:21 #97463
door Ben
Beantwoord door Ben in topic Restoring a Philips F8X82a
Cees, het codenr 915/03 heb ik hier gevonden
www.nfor.nl/index.php?id=314633
Kan zijn dat dit fout is maar het staat wel in de doc van TS Jose.
Heb zelf de B8X72A en daar zijn de 2e en 3e foto van, de schakelaar is niet opengemaakt.
Groet, Ben
Cees, I found the code no. 915/03 here www.nfor.nl/index.php?id=314633
This may be wrong, but it is in the TS Jose doc.
Have the B8X72A myself and the 2nd and 3rd photo are of that, the switch has not been opened.
Regards, Ben
Groet, Ben
Regards, Ben
Laatst bewerkt 07 jul 2023 12:21 door Ben. Reden: Tekst
07 jul 2023 07:41 #97462
Beantwoord door Francois129 in topic Restoring a Philips F8X82a
Hier vind je extra info met Peter in actie.
www.grammofoon.com/frameset.htm?http://w...82A.htm&ContentFrame
06 jul 2023 22:29 #97461
Beantwoord door peter1952 in topic Restoring a Philips F8X82a
Caution: The black switch looks the same as that from a potmeter, but it is different. The on and off position of the swich of a radio are reversed in addition of a potmeter switch.
The same switch is used in several radio’s and also in some phonographs of the 50’s.
Greatings,
Greatings,
06 jul 2023 22:12 #97460
Beantwoord door Cees PA1DBA in topic Restoring a Philips F8X82a
Ben, first picture is wrong, The right one is the black switch like the backend of a switch potmeter.
06 jul 2023 22:01 #97459
door jamovarec
Beantwoord door jamovarec in topic Restoring a Philips F8X82a
And the pictures, they help a Lot!!!
06 jul 2023 22:00 #97458
door jamovarec
Unfortunately the switch was removed, so i do not have it, otherwise I would have tryed to fix it. Thanks for the advice...
